No signal on first boot...help!
either remove battery for 1 minute or use jumper/metal object to connect two pins for a few seconds, i have tried both of these things now.
here
they still stock this board on ocuk, do you think it might be compatability with the gt220?
i guess i will buy a different board, but this was meant to be a cheap project to learn with lol, i was eventually going to build a high end amd pc.
im in a pickle now, i didnt want to spend much on this as it is nvidia chipset and the other system i want to build will be using ati 5770 so anything i buy for this will be unusable on my next build.
I ammended my above post, where you live? Someone close by might be able to test bits for you,
You tried a normal pc monitor?
ive tried two different tvs, dont have a normal monitor, i think my gran has a crt one, i might have a look tomorrow. i live in southport in the north west.
I have this strange feeling you can't use a TV before you have installed windows and graphics drivers to recognise the display. Someone may prove me wrong!
long shot but have you connected the reset wires to reset on the board? in the past iv connected a power or hdd led to the reset pins and it wont boot
