Hi,
Recently my computer's been crashing - I've noticed this when I've been playing videos on my computer or something like flight simulator X.
When it crashes - it doesn't completely freeze initially. It slows down a lot - so for example if I press the key combination, CTRL+ALT+DEL, it will take it's time to come up, but it will come up, and then it'll take time to click "end program" etc. Once the program is terminated, the computer seems to be fine again. This doesn't always happen either and often when I restart my computer things seem to be working fine again. Leads me to think - is this a RAM issue, is it crashing because if the program or video or whatever I'm doing takes up a certain failing part of the RAM, it crashes?
Whilst I was investigating the problem, I updated my gfx drivers to the latest from nvidia, and I then proceeded to the BIOS. I noted that I had overclocked my memory, so I reset it to "auto" which was the previous default setting. However, upon restarting, I now get "no signal" on my monitor. Everything seems to be working fine in the case - lights on, fans working, etc. I took out each RAM stick, one at a time, to see if the computer would boot, and that didn't work. Then I took them both out to see if the mobo would recognise anything, and it did, so it seems the mobo is fine?
Any ideas?
Here's my spec:
Intel Core 2 Quad Q6600
Asus P5K Deluxe WiFi Intel P35 (Socket 775) PCI-Express DDR2 Motherboard
BFG GeForce 8800 GTX OC 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Crucial Ballistix 2GB (2x1GB) DDR2 PC2-5300C3 667MHz Dual Channel Kit (BL2KIT12864AA663)
Seasonic M12 Modular 600W Silent ATX2.0 Power Supply
Creative Sound Blaster X-Fi Soundcard
Thanks
Any ideas?
Here's my spec:
Thanks
