No Signal On Monitor?
7 Jan 2003
Gold Coast, Australia
Hello just built a spec and it is having one teething problem.
Whenever i restart or the computer goes into sleep or the like the monitor wont find a signal from the computer the screen just stays blank but the computer is on and fine. I have to turn the computer off and back on again for it to work properly.
MSI M3-F Intel G31 http://www.overclockers.co.uk/showproduct.php?prodid=MB-114-MS&groupid=701&catid=5&subcat=326
Intel Pentium Dual-Core E5200 http://www.overclockers.co.uk/showproduct.php?prodid=CP-251-IN&groupid=701&catid=6&subcat=793
OcUK 4GB (2x2GB) http://www.overclockers.co.uk/showproduct.php?prodid=MY-014-OK&groupid=701&catid=8&subcat=813
Ati X300
Samsung SpinPoint F1 1TB http://www.overclockers.co.uk/showproduct.php?prodid=HD-053-SA&groupid=701&catid=14&subcat=1279
Any Ideas?
What monitor are you using mate?
Friend of mine is having a lot of trouble with DVI on his 4870 x" on a P5Q Deluxe board. His screen is a sammy and it deciding not to like DVi at all, VGA is fine it's just DVi he's having the problem with.
Dell S2409W 24" Widescreen True HD LCD Monitor - Black
My main rig runs fine through DVI but this system i built is having trouble with the analogue input.
LKike i said it is only when the computer is restarted or goes to sleep, its like the monitor is not told to turn itself on again.
To cut a long storey short, i have ordered all the 'big parts' to my parents house (case, psu, monitor) and i am just installing windows on it here and getting it ready just to take back the HDD, Mobo & CPU to save me carting it back from london.
Could it be that i am using a PSU that is not powerfull enough for the system its a generic 300w one. But i am not running any thing to demanding off it.
All ideas would be a great help, as i want to make sure i give my parents a rock solid computer.
