I'm running out of ideas and need some help.
Spec is in sig.
I purchased a water block for my GTX 280 and added it into the loop today, I stripped the card added thermal tape/paste in the places required etc mounted the block ensuring not to overtighten the screws. Put fresh coolant in and booted up slowly topped up te resevoir and kept an eye out for leaks. So far so good until I realised there was no display! All I get is check signal cable! I have removed my Sound card, disconnected all drives, tried one stick of ram, reset the bios, rechecked cables tried both out puts on the gfx card.
Just don't get it, can't figure out what's wrong.
When I switch on the pc it sounds normal (like its booting up) fans spin, mobo lights up, keyboard comes on etc...
Any ideas, I'm going to have another go tomorrow, bar putting a new card in there is there anything I have missed/overlooked?
Spec is in sig.
