No signal to tv from gpu hdmi !
10 Apr 2014
Hampshire
Just finished doing the leak test in my rig, plugged everything in and im not getting a signal. I checked the connection and even tryed a different slot on my amp.
I tryed different cables and connections on my tv aswell but still no luck. I also tryed turning off the pc , unplugging the power cable and holding the power hutton for a minute, still didnt work.
Tryed removing the battery and then replacing it, that didnt work either.
The motherboard lights up and everything else is working, fans spin and the res/pump are going.
Anyone got suggestions on what i could do to get a signal ?
EDIT : just got a signal and it said power down and connect pci-e power cables for this graphics card but there is a cable in there.
2nd EDIT : apparently the pci-e that i made didnt work , used ine from my psu box and now im up and running.
