No signal when starting rebuilt computer
18 Oct 2002
Hi Everyone,
I just bought a new case for one of my older PCs, it's an Iwill K266plus R mobo, and after I rebuilt it I can't get a picture up on the screen. I hear no beeping at all from the mobo, even though their is a light on, and all the fans, hard disk and GPU have power.
So far I have tried the following.
Replaced the PSU
different memory in different slots
Replaced Graphics card
Built PC out of case with basic setup with no luck, on antistatic bag.
Reseating CPU
And not of it makes any difference, still no beeping or picture. I can't replace the CPU since I don't have a spare that would fit, and probably no chance of finding one either. So I'm suspect the motherboard has had it. Can anybody else think of anything else I can try?
I know it sounds silly but you've put the monitor lead into the graphics card haven't you and not the on-board graphics? :confused:
If your new case has a 12V ATX molex (4-pin) on top of the standard one, you might need to connect that one as well for the mobo to have enough power. I've had that with a new box recently.
I'm afraid the mobo, has no 4 pin connector, it was manufactured before the 4pin cable was standard.
