I've just re-installed Vista and I've got no sound! It was working fine before in Vista but I needed to install it on a different hard drive and now there's no sound
. If I put the mouse over the speaker in the system tray it says 'No audio ouput device is installed'. I installed vista in exactly the same way as I did before, i've run windows update and its updated several things but nothing related to sound.
I looked in the device manager, and there are there are the little warning signs next to the following in the 'Other Devices Section':
-Linksys Wireless card (which i know doesn't work
-Multimedia Audio Controller
-Unkown Device
I dont think this came up before but I cant see how it's naffed it up when I haven't installed anything apart from windows updates
. Is there anything I can do bar a fresh install?
. If I put the mouse over the speaker in the system tray it says 'No audio ouput device is installed'. I installed vista in exactly the same way as I did before, i've run windows update and its updated several things but nothing related to sound.I looked in the device manager, and there are there are the little warning signs next to the following in the 'Other Devices Section':
-Unkown Device
