Hello all,
Two years or so I purchased a Soundblaster AE-5 soundcard and it worked superb until last year when I turned on my PC and all I got from the card was low, crackling audio. I troubleshooted it like so:
- Re-seated the card, issue remained
- Tried different outputs, issue remained except the front I/O Panel headphone out worked fine
- Reinstalled Windows, issue remained
- Tried Linux (Manjaro) issue remained
- Tried a different PCI-e slot, issue remained
- Tried onboard, it works flawlessly. I tried ensuring onboard was both enabled and disabled but makes no difference.
Now this is where the issue gets weird:
- I tried my old Soundblaster Z card and that showed exactly the same symptoms so I figured maybe it was my motherboard having some weird issue (My GPU was working fine mind you)
Recently I upgraded my PC so new CPU and Motherboard (everything else the same) and the issue remains with both soundcards?
I thought maybe it was my PSU (A Be Quiet! Pure Power 10, 700w) though the Z doesn't need molex power like the AE-5 but I connected up a 350W PSU to my old motherboard without a GPU/case etc as a test bench just to test and the issue remained
I am super confused. 2x soundcards not working with the exact same issue on 2x motherboards with 2x OS's
