No sure of memory settings.
12 Feb 2009
N.Ireland
No sure of memory settings, advice please.
Hi just built this yesterday and wondering if the memory setting is OK
Thanks in advance
Looks fine!
How's the build treating you? What have you paired with that G4560? :)
Build was straight forward thanks, no probs, so far :)
Sorry, what do you mean by "paired with that G4560" :)
I ended up using the stock cooler btw.
Ahh :)
Just the on board graphic, its just my daughters home PC just using it for some light internet use and home work for the kids.
It was long over due an upgrade so I got the MB, processor, memory and PSU and windows 10.
So far all working good, touch wood :)
Just curious :) you guys know, unlike me, what the correct setting to use/change in the BIOS regarding memory. What it should be running at etc. :)
Is there a rule of thumb?
Thanks in advance.
