Hi,
I tried to install a 6800GT (AGP) into my MSI K8N Neo2 Platinum, but upon power on I get nothing but a mess of white and grey pixels.
It is second hand from someone who is confident it worked before (and I can trust this person, they aren't having me on).
I am using a Thermaltake 480W PurePower, on which I used a clean Molex channel.
I uninstalled the old drivers.
I reset the CMOS
I checked for dust.
I tried different monitors/outputs.
The fan powers up, and I get standard "everything's OK" bleep. It continues loading, passes POST, etc, just shows a mass of pixels. You can't even begin to make out what is on the screen.
I used all correct static precautions.
And finally, my 9800Pro works with no problems in the same slot, off the same molex.
Any ideas?
I reset the CMOS
I checked for dust.
Any ideas?
