ok i just bought some new components for my computer, I bought a new case (cm scout), another XFX HD 6870 (for xfire), and a new mobo (Gigabyte 890GPA-UD3h).
Now I installed the mobo, put in my cpu (Phenom II 965 x4) installed a cooler etc.. and put in both the graphics cards. Now i'm not getting any visual on my screen.
So I decided to do some fault finding, I checked all the cables they seemed plugged in fine.
So I took out the GPU's and tried using the onboard VGA, same result. PSU is 700w coolermaster. Please help :S
Edit: I also forgot to mention i put the ram in both the grey slots DDR3 1333Mhz 4gb because my heatsink covered up the top slot
