No voltage control MSI 280X
Man of Honour
20 Sep 2006
Just got a couple of these and I don't seem to have any voltage control in MSI afterburner. I've reinstalled the drivers and MSI itself and started again, but it's still not an option to move the slider. I was able to control it on the previous Powercolor 280X cards.
Tried making your own bios? I had similar issue with my powercolor 7950s. I could change it in ab but cards always ran at 1.25. So I made custom bios with voltage 1.1
Are you running the latest AB and have unlocked voltage control in options etc?
From a review:
Power is delivered via the CHiL CHL8228 controller, so voltage can be controlled via compatible software.
This controller has been in use for a while (Vapor-X 7970 had it) so it's strange that it wouldn't work...
But you're not alone, something is clearly up with these cards: http://forums.overclockers.co.uk/showthread.php?t=18562377
I think I might know what's going on. From [H] review:
The MSI R9 280X GAMING can also utilize the new MSI Gaming App, which has three settings users can choose from. Silent mode, Gaming mode, and OC mode. Silent mode will lock the core speed at 1GHz. Gaming mode will lock the core speed to 1020MHz, and OC mode will lock the core to 1050MHz. Unfortunately the app doesn't immediately overclock the video card past 1050MHz, you will have to manually do this through MSI Afterburner.
http://www.hardocp.com/article/2013/10/28/msi_r9_280x_gaming_video_card_review
Check out this Gaming App mate.
http://www.msi.com/service/download/utility-21524.html
http://www.msi.com/product/vga/R9-280X-GAMING-3G.html#download
hey had the same problem you had.. im wondering are you doing this to mine btc? do you mind telling me what voltage and cor/mem settings you used? i would really appreciate your help and your findings.
hey man i am in the same boat you were.. i have updated my bios. are you doing this to mine btc? do you mind sharing your findings? what did you set your voltage to? and your core/mem settings? would appreciate your help
