noblechairs ICON PU leather review.
Caporegime
17 Jan 2010
weston-super-mare
Noblechairs2_zps7kjyntvc.jpg~original
OcUK Product page - https://www.overclockers.co.uk/noblechairs-icon-gaming-chair-black-gc-00h-nc.html
noblechairs Product page - https://www.noblechairs.com/p/icon-series-black
Today I have something a little different, a £320 chair from noblechairs, is this chair worth £320 of your money is the question?
Gaming chairs have become ever increasingly popular from roughly 5 years ago and now can be found in many events not just gaming orientated, maybe you want a nice comfortable office chair? maybe you are not a gamer but have another occupation that requires long periods of sitting down and need a sturdy and comfortable chair.
The new noblechair ICON series available in PU leather or real leather sets out to fill those criteria.
A few of the highlighted features are,
• 2yr warranty
• BS 5852 fire certification
• 1.5mm steel construction
• 480mm - 580mm seat height adjustment
• 180Kg maximum user weight
Packaging
DSC_0812_zpsezozdvjn.jpg~original
This is the box it arrived in. It surprised me by just how heavy it is! even the DPD driver was cursing me and it lol, it is almost a two man lift if you want to get it upstairs.
DSC_0815_zpsyb67t4kg.jpg~original
Everything comes individually packaged inside the box.
DSC_0823_zpsvkblqmdl.jpg~original
This is everything you get inside the box, nice to see two support cushions included.
Overview of the parts
DSC_0885_zps1aq1awuk.jpg~original
Assembly instructions.
DSC_0888_zps8dmcymee.jpg~original
In the smaller box you will find all the screws and wheels and bits needed to assemble the chair, no additional tools are needed as a wrench is included.
DSC_0831_zpszrvahhf4.jpg~original
These are the two support cushions, one is a headrest with elastic strap to hold it in place, the other is for your lower back area and does not have anyway of staying in position.
DSC_0833_zpsorbrv8v0.jpg~original
DSC_0836_zpszq6q8vud.jpg~original
This is the base frame and is of an all metal 2mm steel construction rather than plastic as found on cheaper chairs so should last forever, I have had cheaper plastic bases break on me.
DSC_0857_zpssxjrreco.jpg~original
DSC_0859_zpsgnnesbmh.jpg~original
This is the chairs main adjuster/tilt mechanism and again is a solid and weighty item made from nearly all metal.
It has height adjust levers on both sides.
It also has a rocking mechanism with 11° tilt.
DSC_0841_zpskn9tyxyn.jpg~original
This is the bottom seat, it has height adjustable arm rests, back adjustment lever, metal frame construction with a foam and 1.5mm PU leather cover which is apparently 25-60% thicker than alternatives.
The chair has UK fire regulation (BS5852) certification.
DSC_0844_zpskzgdb879.jpg~original
DSC_0845_zpsqdewx4yg.jpg~original
There is a good range of adjustment on the armrests.
DSC_0851_zpsd0tmrili.jpg~original
DSC_0847_zpsbsgbefic.jpg~original
The finish and stitching is of a high standard.
DSC_0861_zpsyarovors.jpg~original
This is the backrest and once again has a metal frame construction covered by foam and the same 1.5mm PU leather.
DSC_0880_zpsbpgm2ud2.jpg~original
The back of it has a smooth finish.
DSC_0867_zpsisanqtju.jpg~original
A little bit of branding is found near the top.
DSC_0874_zpsri9ydmco.jpg~original
Again the finishing is of a high standard.
Assembling the ICON chair
DSC_0894_zpsoggsfgcb.jpg~original
First thing to do is to attach the adjuster to the underside of the seat using the four included (there is also one spare should you need it) bolts+washers.
Also note that you can adjust the armrests in or out of the base.
DSC_0895_zpswasmp5wf.jpg~original
Then push the plastic handles on to the the height adjusters.
DSC_0898_zpspfpu4qkx.jpg~original
Next push the five wheels into the base.
DSC_0900_zpsvtt4qqnd.jpg~original
Flip the base the right way up and insert the gas strut and the plastic shroud.
DSC_0902_zps7lqpy68y.jpg~original
DSC_0901_zpsgrpnujxy.jpg~original
Place the seat onto the gas strut and sit on it to insure a good correct fitment.
DSC_0904_zpsunimt8w8.jpg~original
Attach the back rest to the bottom with the included bolts and washers.
DSC_0908_zpsctmnfmim.jpg~original
Then cover these up with the two supplied plastic covers and two screws.
DSC_0909_zps99kitxul.jpg~original
DSC_0913_zpsrce1jqr9.jpg~original
Place the cushions onto the seat and it is complete.
The completed chair
DSC_0919_zpsol9kv4yj.jpg~original
DSC_0916_zpshttbykd1.jpg~original
So here we have it in all its glory.
It looks the part, is comfortable to use, has great adjustment on the back that can go 90-135°
While the arm rests are adjustable in height I find for me that in their top most position is best as I can rest my elbows on them while gaming or typing, they have an almost soft plastic feel to them so are not harsh on your elbows.
DSC_0008_zps1y1anvvb.jpg~original
The armrests can also twist in or out via a button on each one.
The wheels glide around smoothly on my short pile carpet.
There are also no strange creaks or groans from it, it is designed to support up to 180Kg so even larger users are well catered for.
All this is backed up with a 2yr warranty.
So is it worth £320? well compared to my previous Nitro concepts E200 I would have to say yes as it is clearly better made and has all this adjustment available to it.
My only single gripe is the lower support cushion doesn't stay in place like the headrest one does as it does not have any sort of elastic strap to keep it in place, so as soon as you get off the chair it falls down and I find myself always having to place it it behind me as I sit back on.
thanx for the review man ive just ordered the red icon :) should be much better quality than my ak racing right :p :p ? how is the quality compared to dx racer, this is better?
I had a nitro E200 prior to this, there is no doubt this is better made, more comfortable and has way more adjustment, I just found out that the arm rests also slide backwards and forwards.
I think you need to vastly expand your comparison in order to be objective.
If Noblechairs want to send me a review sample I'll happily stand it next to my Steelcase for a comparison on features, quality, price/value etc both from a PC gaming PoV and for work.
Can you completely remove the arms if you wanted to? Really not a fan of arms on chairs (personal taste + errr a width issue :p) but a lot of chairs they are integral to the stability!
