Noctua 140mm fan
Permabanned
13 Mar 2013
I have the Noctua D14 installed and the middle fan, the 140mm is making a hell of a noise due to it vibrating, it is held in firmly but its still vibrating, if i unplug it the noise stops.
Ive youtubed some vids of it in operation and mine is way noiser then theirs!
I am clocked at 4.4Ghz on an Ivy I5k. Temps are really good but the noise is dreadful!
I am in contact with Noctua already and they have already send a replacement 140mm which did not fix the problem.
Has anyone with a Noctua D14 come across this?
Many thanks.
did u use the rubber strips?
edit, just noticed OP is permabanned lol, after 3 posts must be a record
