Noctua advice please
6 Jan 2009
Hertfordshire
Hi guys i'm wondering if you can help me
I'm looking at getting this cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-NC&tool=3
And just wanted to make sure it will fit on my striker 2 formula mobo.
I'm currently using the stock heat sink and fan and using an antec 900 case.
It looks DAM ugly but Ive heard it performs VERY well so i'm willing to take its appearance with a pinch of salt.
Check the Noctua website as it has a compatible motherboard listing
Not always accurate though. I checked the to see if the Noctua would fit my Giga EP45-Extreme and it says it doesn't.
I'd beg to differ, it does fit. Been working on mine for the last month.
I'd still get advise from users if I were you.
