Does anyone else find these things impossible to use?
They state pull through the fan, in many instances there is no way you can reach the peg to pull it through the fan, as its in the back corner of your case blocked off, or if you have two fans mounted side by side, who can't get at the rubber peg for the second fan to pull it through. Is so frustrating, been at it forever with needle noise pliers. Is prob easier if you fit the fans when the case is empty, but still a ball ache if you are mounting fans side by side etc.
Im losing my mind and thinking of just using conventional screws. Will it make a difference?
