- 2 Aug 2006
- Liverpool
hi what air cooler will be better cooling my future 3900x build, noctua d15 or be quiet dark rock pro 4, case is a fractal design meshify c (non windowed)
D15S is not just about RAM, its about your Mobos's top 16xPCI-E Slot (the native/CPU slot one on most Mobos if you only have one 16x native/CPU slot with rest Electrical only)
If they claim to match their 140mm cooler with their new 120mm cooler I would like those improvements put into a new 140mm Black cooler so a D16/16S Chromax or such.
If your saying you seen this mentioned somewhere please link to it.![]()
I tried some keywords but came up with launch of older D15/S.
i have the dark rock pro 4 and still deciding on sending it back as i have not used it yet, was thinking of the NH-d15 chromax pure black but not to sure as its a good £40 more than the dark rock pro 4. is there a lot of difference in temp cooling between them ? and sound levels
going onto a gigabyte master and 3900x in a h510i case
