Noctua fans, C70, PWM and case cooling questions
23 Apr 2010
London, UK
I'm doing a C70 build. I've already decided on a NH-D14 SE2011 cpu cooler so don't need to worry about static pressure fans. But given that the C70 has umpteen bazillion 120mm fan mounts I need to decide on two things.
1. A decent 120mm fan.
2. PWM or no PWM for use with a Lamptron FC5V2 fan controller.
For #1, based on Noctua's website advice (http://goo.gl/hnv3Q), I decided on the NF-S12B FLX (http://goo.gl/7K7KD) as it was the best airflow fan they had. However then I realised that this is 3pin and does not support PWM whereas the NF-F12 (http://goo.gl/1S8IR) which is best for static pressure, being 4 pin, does support PWM. So now I'm a bit confused and need some help. My questions are:
1. Given that NF-S12B FLX does not support PWM -if I plug it into a fan controller like Lamptron FC5V2 or a mobo header - will it always run at max speed (assuming no use of the low noise adapters)?
2. If fan controller voltage is turned down will NF-S12B FLX just turn off if voltage is inadequate?
3. Why do they not have PWM for their airflow fans and only for static pressure fans? Is PWM not necessary for airflow?
4. I've noticed that some reviewers out there use NF-F12 for everything which I'm finding a bit strange. Why would you need static pressure fans for case cooling? Is it because they support PWM?
Would appreciate some light on the above from the experts. Thanks.
Thanks guys. So correct me if I'm wrong. A fan speed can be controller by either adjusting voltage or by PWM which are two different methods. So even though the airflow fan may not support PWM it can still be adjusted through voltage? And I'm guessing Lamptron FC5V2 uses voltage control?
Thanks. Yes I agree they are horrible. I'm all for aesthetics so if you know better looking ones do share. :) Though to be honest the aesthetics will already have been devastated by the use of Noctua fans anyway so it won't matter! Lol!
