Is "Noctua NA-SRC7 4-Pin PWM Low-Noise Adaptors, 3 pack" the only way to reduce your fans rpm without using a fan controller ?
For reference i have a 750D with
6 x Noctua NF-F12 IndustrialPPC 2000RPM IP67 PWM 120mm High Performance Fan
4 x Noctua NF-A14 IndustrialPPC 2000RPM IP67 PWM 140mm High Performance Fan
connected to Lamptron FC5 Fan Controller V3 5.25 inch
Cooling 2 x Sapphire Radeon R9 290 Vapor-X OC 4096MB GDDR5 PCI-Express Graphics Card
So as a novice i originally choose to connect them all via fan controller since i had the intention to just dial up and dial down the knobs when the gpus reached high temps but quite frankly all ive had to do is macro 3 msi afterburner profiles to set my 2 gpus fans to 30% 40% and 50% for when i play high intensive games. the knobs on the fan controller are soooooo sensitive i never bother touching them and often when i turn my pc on i have to reset 1 of the knobs back to its original rpm as for some reason it went back down to 0rpm.
So im thinking of scraping the fan controllers, sell it off and daisy chain all 10 fans to the psu via Noctua NA-SRC7 4-Pin PWM Low-Noise Adaptors, but i noticed these only reduce the rpm by 30% and i like to keep all my fans at roughly 1080-1140 rpm any more and the noise can get too high since my pc on on my disk 2 feet away from me. Are there any other choices ?
With somthing like http://www.overclockers.co.uk/showproduct.php?prodid=CB-070-AK
http://www.overclockers.co.uk/showproduct.php?prodid=FG-030-NC
