Noctua NA-FC1, 4-Pin PWM Fan Controller
11 Jul 2003
Telford//west mids
Can i use this too turn down a ddc pump as its to fast and causing bubbles in the loop.
Thanks.
Yes it's a four pin just wanted to make it would work thanks.
I am leak testing my loop and the pump is causing bubbles so I need somit to turn down the pump as I've got the flt 80.
It controls more than one fan.
remeber the Wattage of the PUMP, the controller will have a max output normally around 15w for most controllers
What model of pump do you have and what other fans will you want to run off it
Laing DDC pump 12V 18W DDC 3:25 no fans will be running on this it's just for the pump.
I'm doing the exact same thing when I (eventually) tube up and just grabbed this controller off the MM.
The controller comes with 2 input cables: one that is a simple 4-pin extension for connecting to the motherboard, the other is a split input with a motherboard connector without the 12V wire and a separate SATA connector to power direct from the PSU so you can drive lots of fans or high power fans that would normally overload the fan header.
You'll need to use this split input if you're going to control the DDC for bleeding because the controller itself, obviously, needs to be powered. So if your DDC pump has separate Molex/SATA for power and PWM cable, obviously hook the DDC into the PSU. If your DDC only has the single 4-pin cable, the PSU power coming into the controller will be plenty to drive the pump as well.
Note however this fan controller is a PWM generator, it's not a variable resistor. So if your DDC is actually voltage controlled, the fan controller will not work as it's always outputting unmodified 12V power.
