- 18 Sep 2011
Hey guys, was wondering if anyone has fitted one of these with a P8P67+Corsair Vengeance and if it fitted ok? I've had a quick look around and people say you miss your first ram slot due to fins but the second ram slot all you need to do is move the outta fan a bit higher on the brackets, was wondering if anyone had some experience with the RAM + CPU.
Oh and how would this perform compared to a custom water loop? For £150 more I could purchase a res, cpu block and all the accessories to go with my Laing D5+Swiftech Rad. I will only want to get my CPU overclocked to about 4.4-4.6ghz max. It's a 240 radiator with only pull.
Any other suggestions are welcomed though, if something is cheaper and will do the right job for me then it would be great.
