Hello guys,
I recently put a system together with the Noctua Nh-d15 and the Enthoo Pro.
The case comes with a fan power board that allows for 5 fan connections.
I currently have the 2 fans on the Noctua connected to a Y-splitter that goes into the CPU fan slot on the motherboard.
I wanted to connect the Y splitter cable to the fan module but after seeing this message on the manual I have second thoughts.
My question is.
Can I ignore the warning on the manual and connect the Y splitter (2 noctua cpu cooling fans) to the fan controller and subsequently the pin on the controller to the CPU fan slot.
If not what are my options to have all the fans in my case (currently 5 including 2 noctua cpu fans) connected to a PWM controller.
Thanks
My question is.
Thanks
