Noctua NH-U12P fitting
22 May 2007
Hi,
Can anyone explain where the fan goes on this puppy?
Do you fit it on the side of heatsink nearest the back of the case or the side furthest away?
Then, which way round does the fan go, how do you know which way it blows the air? Sounds like a daft question but I've put my hand near it and can't tell!
Thanks.
Bob.
Hi mate,
You put it whichever side suits the airflow of your case. Mine blows air through the sink and directs it to the exhaust fans. Seems to work well this way.
Point the sticker in the middle of the fan in the direction you want the air to blow, if that makes sense :)
