Hi all, I have just fitted my new noctua cooler to my pc (in sig) and have't improved on temps at all.
I was running on stock HSF and ran core temp last night and measured at about 33-35c on idle. which i though was pretty reasonable. but my temps after fitting the new noctua haven't budged.
First question is there better temp monitoring software that i can use on vista64 to double check, and also are these reasonable temps for my rig?
There is no OC applied its all stock. (im worried i might have put to much paste on, but it seemed rather thick in comparison to other pastes ive used in the past, although i only put a REALLY thin layer on)
any ideas on this?
any ideas on this?
