- 18 May 2010
- London
I have a Thermaltake armor case, and have just purchased a Noctua coller, but the fan in the side panel of my case is too big to fit the noctua.
According to the website: http://www.thermaltakeusa.com/Product.aspx?C=1277&ID=1405
The side fan is 25cm.
I'v removed the fan, but the dust gueard is loose now and leaves a gapping whole.
So I need to find a 25cm thin fan to replace it.
Any ideas?
Even just a grill would do.
I cant seem to see any 25cm fans/grills etc...
Maybe I send the noctua back and get a cooler similar in performance thats smaller?
Any recommendations?
Any ideas?
