Noctua u12s vs AIO on ryzen ?
29 Dec 2012
Hi guys I had a question regarding air cooling vs AIO.
I have a Noctua U12s at the moment on a 1700x which I will hopefully be upgrading to a 3700x, I wanted to know would I be better to stick with the Noctua or look at AIO?
I will also try to overclock the CPU, from online vs reviews, it does not look to be a huge difference but I don't think any of them had been overclocked.
I wanted to ask for first-hand experiences.
I have no idea of AIOs, If I went for an AIO, I would be looking at the low end due to budget.
Hi,
I had a a U12S cooler, with 2x120mm fans, and it cooled my 10600K nicely, but when I upgraded to a 18050K it struggled a bit, I changed to a Corsair 240mm AIO and its great, and also my system is sooo much quieter.
Hi,
What model was the aio ?
also was the cooling better or was it just the noise ?
Thanks, was it a huge difference or just noticeable?
tbh, quite a difference, dropped temps on a modest bios setting around 12-14 degrees. And the noise reduction is more from my GPU I think..
It can be hard to tell which components are causing what levels of noise..
I'm quite sold on AIO as a minimum because it just redirects heat away from other components if positioned correctly.
Also any AIO solution also means fans spin more consistently and there is a ramp up of temperature. Overall, gives a better look with less clutter
I am considering a AIO But I have no idea which to get and which to ignor
I came accross this when looking
Arctic freezer offer the best value and have a very thick radiator so check clearance to thr motherboard if fitting at the top of your case.
I have the phanteks primo at the moment and hoping to get the Lancool 2 mesh or 011 evo when it comes (If priced well) also How do I check the clearance ?
I'm surprised @doyll has not replied yet he's normally good with this type of question.
Manual or email to manufacturer, maybe another forum member may know.
