Nod32 Killing Msn?
17 Jun 2005
Near Brighton
Ive got the free version of nod 32 installed and ive got this problem where msn just crashes when i try to sign in. This happened a few weeks ago when it was installed, uninstalled it and problem went away, re installed but its still happening. How do i fix this?
edit, it still does it even when nod32 is not running, any ideas?
I dont think its nod unless you have configured it wrong although i doubt that. I've been running NOD32 for a while and I have had no problems with msn, 7.5 or 8 Beta. Perhaps its something else you installed?
hmm well its fine until i install free nod 32, i tried exiting it still didnt work. then i unistalled it from add / remove and it worked so it must be nod 32
im using msn live 8 beta
