Nod32 + Outpost Firewall problems
23 May 2006
I thought i'd switch to Nod32 cause Kaspersky was hogging up resources and it screwed my machine up.
Now for some reason Nod32 wont work with outpost firewall, some sort of confliction between the two cause my machine constantly goes in to continuous reboot when it reaches the windows login screen. if i remove either of them then the comp boots up fine. im now having to use XPs built in firewall with Nod which im not keen on
I was just wondering if anyone else as had similar problems using these pair together ?
ive got Nod32 - v2.70.39
outpost firewall v1025.700.303
Odd. I never had any problems running the two together.
It's probably just a compatibility issue with the current build of one of the two. Try to find a slightly older build of either.
