Node 3 Cooling Fans Dilemma
11 Feb 2006
Hello
I have just built a new PC
Node 3 Case
Asus rog-strix-b760-i-gaming-wifi
i7 13th Gen 13700
32gb Ram
The Node 3
comes with two 120mm fans at the front and 1 140mm fan at the rear and I have the stock intel cooler
The CPU fan cuts in and out depending on load but sometimes its quiet loud - I have set to quiet in the BIOS but still pretty noisy so
I'm thinking an AIO with 120mm fan but that means I will lose the 140mm fan at the back
or should I replace the stock cooler with something better - suggestions please
I am not overclocking or gaming much just looking for less noise
Any advice or options please
Thank you
Hello
Node 3 Case
i7 13th Gen 13700
32gb Ram
The Node 3
Thank you
The case can take a tower cooler Upto 160mm. Taken from TPU website.
A decent low profile cooler will be much better for you. OCUK has great range of low profile coolers that will be the quietest and best performing solution.
I personally like some of Jonsbo LP coolers.
