- 9 Oct 2013
- United Kingdom
I'm planning a x99 MATX build using the EVGA Micro 2, a 5930k and dual 980Ti's. Ideally it will be watercooled by a single loop in a parallel set-up using two 240mm radiators.
The problem is, the clearance for the GPU's in the 804 is very limited (Seriously fractal? Another 30-40mm in length would have gone a long way). From the measurements on the Fractal website, you simply can't fit a 240mm radiator with fans (even with a slim rad and fans), however I am determined to make it work.
Can someone with a 804 please measure for me the distance between their card (and what length their card is of course) and the front of the inside of the case. I want to know exactly how much space I've got to play with to see if I can work around it, or easily mod the case to make it fit somehow.
Thanks, Nathan.
Thanks, Nathan.
