- 23 Jun 2014
- Cornwall
Hey all, I'm in need of some help to solve a big problem here...
I've got a noise/interference problem on the mobo onboard sound outputs. I've tried going from both front and rear sockets using a 3.5mm to RCA cable going to a stereo Hifi amp, high end monitor headphones direct to the PC sockets and desktop multimedia speakers. As well as this I tried going out to my Avid MBox Pro firewire recording interface RCA inputs and I have this awful high pitched and low pitched (simultaneous) constant tone that changes when I move the mouse, open a window or program, game etc and if there is any HDD or SSD activity it stutters in time with the drives accessing data.
I've tried short cables, long cables, plugging into a high end multi socket surge protector, direct into the wall socket etc. I've also made sure everything is plugged into the same socket to make sure it is not a ground loop caused by plugging into different power sockets. I've even tried grounding the RCA cables to the chassis of the PC, the Hifi amp and I can't get rid of the problem.
If I set the MBox Pro as the default playback device in Windows sound settings and have the sound go through firewire to that and out of my studio monitors (which are connected using Balanced XLR cables then I don't have any noise issues. I cannot leave it set that way though, the MBox cannot function correctly for Pro-Tools recording when set as the default playback device, I just did this as a test to see if I get the noise this way.
I think it is interference coming from one or more components in the PC. It is so bad that I can't put up with it but I don't know how to fix the problem.
I've read online about other people having this same problem but most don't come to any conclusion or solution. Some solved it by grounding the RCA cables to the chassis of their amplifier. Others did something dangerous using what is known as a ground loop adapter or cheat plug, whereby it removes the earth cable from the power supply plug so they effectively have no earth. Some I read actually bought PCI, PCI-e or Firewire sound cards and this got rid of their problem. I can't do this as I have no accessible slots on the motherboard due to the GPU's covering the remaining available slots. One guy talked about ground lifting his speakers but didn't explain in detail.
I'm lost on this one and other than yourselves and OCUK the only other option is to contact the component manufacturers and see what they might suggest. It is likely that they will just blame it on other components in the PC but won't obviously be able to tell me which components are causing it and certainly won't admit that their component is known to cause this.
I really hope someone can help with this one as it really is a dealbreaker because it is so bad I cannot live with it like this, especially on a brand new £3000 PC!
The PC has in it:
ASUS Rampage IV Black Edition
Intel i7 4930k
2 Inno3d GTX 780 6GB SLI
EVGA SuperNova 1000w G2 Gold
32GB Kingston HyperX Beast PC3-17100C11 2133MHz
Crucial M550 256GB SSD
2 x 1TB Western Digital Caviar Black
2 Pioneer BluRay Drives
Custom Watercooled Loop using and XSPC X2O 750 Dual Bayres/Pump V4
NZXT Phantom Enthusiast Case
3 x 120mm Bitfenix Spectre Pro Red LED
1 x 140mm Bitfenix Spectre Pro Red LED
2 x 120mm Bitfenix Spectre Red LED
Thanks for any and all assistance.
The PC has in it:
Intel i7 4930k
