- 30 Oct 2014
- Norfolk
So i've seen people about talk about noise dampening material you add to side panels to make the case more silent? Where exactly can i find this stuff and guides to installing it?
http://www.overclockers.co.uk/productlist.php?groupid=2362&catid=1170
Choose the sizes you need. Plan and double check though.
Bare in mind that it will also insulate your case slightly. Probably 5 degrees or so maybe which isn't much really if you have good coolcooling which you do in your Primo.
