Hi
Does anyone know what the correct noise margin I should have on my line to get the best broadband speeds while still maintaining a connection?
BT have been out and sorted the noice on the line which reduced the noise margin to 5.0 db and since then the line constantly dropped.
I have contacted Be Un Limited and they have increased the Noise Margin to 7 db and the connection now holds however speeds have reduced from 16mbps to 12mbps.
Im paying for 24mb broadband and only live a mile from the exchange.
Here's my current router stats:
Thanks
Code:
DOWN UP
Connection Speed 12511 kbps 714 kbps
Line Attenuation 28.0 db 14.2 db
Noise Margin 7.1 db 1.2 db
Thanks
