'Noise reducing curtains'
Consigliere
12 Jun 2004
SW17
Just wondered if anyone had experience with these?
It is for use in a bedroom with single glazing. Upgrading isn't an option so looking at other solutions for now. :)
I have Homescapes thermal blackouts which also have some noise reducing properties along with H.Versailtex curtains which also have thermal and noise properties - the combination does noticeably attenuate traffic noise, etc. but don't expect miracles. There may be other makes/models which are better as it isn't something I've particularly thought much about just they happen to have those abilities.
In terms of the room temperature and noise reduction though it is noticeable.
I've ordered and fitted one set of secondary glazing from these guys last month, got a second set on order.
Got the normal magnetic kit (not extreme), and 4mm thick.
This is the order page I used, you can spec the sizes and add how many roles of tape you need to match the perimeter of your windows. Each tape is 5m long
Has done a decent job of reducing the sounds of overhead planes and keeping the heat in a bit better.
