Noise when in games from a 4850
3 Mar 2004
Sheffield
Hey guys,
Just put my sexy new 4850 in and loaded up WoW and i get a weird sound coming fomr my computer, i switch to desktop, it stops.
Loaded up HL2, same happens
Its not the fan, and im only presuming its the card as everything was fine 20 minutes ago and its the only thing that has changed
It isnt a really loud noise...but its enough to be able to hear
Any ideas? had a gander on google but that hasnt brought much up, only that it may be the GPU??
cannot find the option to enable vsync in CCC at all :/
scrap that found it...still makes a noise though :(
Might look into a new PSU then...if not its not just going to implode is it? :p
Install rivatuner then use the D3D overider program that comes bundled with it.
You can force Vsync then
managed to get vsync on but sitll makes the noise :(
not able to shell out for a new psu till payday now though so i just dont want tha card to blow up or anything :p
Explain the noise?
Is it a high pitched squeaking sound? or something else
If the card is new i would sent it back under DSR (7 days) or RMA.
I had a very similar problem with a ATI 4890 and had to send it back
Explain the noise?
Its kinda of a squeaking noise, have only just receieved it today from OcUK
Me personally i would send it back,but thats upto you.
The chances are you could buy a new PSU and still have the sound.
Not sure what else you can try tbh,sorry
EDIT: What make and model PSU do you have?
Antec NSK6500 Super Midi Tower Case - 430W PSU
Bought that from OcUK a few years back and it has a 430 Watt ATX12V v2.0 in it, didnt realise it was only a 430 though, which if it does need a replacement, i can put this psu in an old computer i have upstairs that i think the psu has gone on :p
Just booted up Wow again and taken my case side off, it sounds more like a fan is catching something...have "manually" stopped all the fans but its none of them...dunno wether to just keep it and put up, send it back or RMA it and go without for a few days, which is crap cos im off work for a week :(
Have had the case off and had a good listen around, turned pc off and checked all conections and everything. I dont think its a capacitor as its not that much of a squeak, more of a whirring sound than anything, but as i have said its not a fan
Might try RMA it, if its the same then ill get a new PSU sorted :(
Sure its not the fan in the PSU? Random noises in pc cases can be so frustrating, in the past few days smoething started making a noise that sounds like a fan though doesn't seem to be any of the fans, I think this one is actually the PSU starting to go bad, though it could be the PSU fan but because of the angles and a huge tower heatsink I can't get anything like a pencil in to stop the fan to see if the noise stops.
its odd how you can stick your head almost right into a case and still not be 100% sure where the noise is coming from :p
Its possible its the PSU fan spinning up higher/harder than ever before if you've never had a card that uses as much power as the 4850 so the PSU is hotter than ever before and fan increases speed as the load or temp does.
I have to say that I've had lots of cards that others appear to have had capacitor squealing with and I've never experienced it to date, but have always had a more than decent PSU with ample headroom(currently a 1kw Thermaltake toughpower, I got it for a steal at £90 and at the time was one of the most efficient out there and still is VERY good).
I'd say a 430W isn't bad, and its a good make, but depending on what cpu/memory/hdd/fan setup you have you're unlikely to be pushing the limit but might not have that much headroom, people also say PSU's do degrade over time and won't be rated to the same power after 3 years so a new PSU might not be a terrible idea anyway and might fix it.
I'd also just double check with vsync in WoW, there should be an option in the WoW options in game to enable vsync.
Vsync and triple buffering in the control panel are for opengl only as "officially" MS doesn't allow the options to be in drivers for directx games for some ungodly reason, well basically DX games don't have to support vsync and trip buffering so WHQL approved drivers can't have the option or something ridiculous. So unless the game offers it you sometimes have to use dxoverider or one or two other apps to force vsync and trip buffering in some games.
Any chance you could try it in any pc's of friends of family? If anyone has a half decent computer you could try it in, if it works fine with no squealing it would probably point more towards the PSU than anything else.
The absolute worst thing when these things happen, is when its just coincidence and after lots of messing around and changing things and upgrading, it turns out to be something ridiculous and nothing to do with the gpu/psu.
Have just sat on the WoW login screen, turned vsync on and off in the options and the noise changes, its a more high pitched whirring sound with it off, then quietens down and becomes more "dull" sounding with it on.
Cant say i have anyone near me with a decent PC at all, which sucks :/
The whining noise comes from chokes not capacitors (although a bad capacitor can cause the choke to squeal more) - if you take apart a PSU you will see large globs of hot glue applied to the chokes for this reason.
If the noise started with your new card then i would start there. Either apply some glue from a glue gun, or try some electrical tape to dampen things down.
Cant say i fancy opening the PSU up to be fair, dont wanna break that as well >< :p
It's the chokes on the 4850 not the PSU.
Under high load they will squeal on some cards. You can fix it sometimes by putting hotglue over them to stop them vibrating.
Or you could RMA it and hope you get a card that doesn't have that problem.
Not much I can say that hasn't been already but I doubt your pulling anything near 430 watts so the psu shouldn't be an issue unless there's something wrong with it.
Most people buy stupidly high wattage psu's just because they think the big numbers are needed for Sli and stuff, this is because Nvidia/ATi specify stupidly high wattage in order to overkill what's required so it never blows back on them, you will generally find that an Antec 430w psu will outperform a generic 600w one because watts are not the only part of the equation and quality > quantity.
My current rig has a Q9650, 2 sticks of DDR2, a HD4870, a 15K Scsi drive, a Sata DVD-RW, a USB soundcard and a truckload of cooling and its pulling ~350w
