- 20 Jul 2009
- The bleak North East arm pit of Britain
Hello
Take a look below at a small selection of the range and click HERE to see them all
Noiseblocker BlackSilent Fan XK1 Fan - 140mm @ £8.99 inc VAT
The fact that good quality does not have to be expensive is shown by the third version of the NB-BlackSilentFan series. The well-balanced properties of this bestseller make this inexpensive and high-quality series of fans the absolute bestseller throughout the world.
Our least expensive series of fans moves in such high circles, however, that other producers come off worse in direct comparisons even with their considerably more expensive "high-end" fans.
- Dimensions: 140x140x25mm
- Noise Level: 12dbA
- RPM: 800rpm
Only £8.99 inc VAT.
ORDER NOW
Noiseblocker BlackSilent Pro Fan PK1 Fan - 140mm @ £11.99 inc VAT
The high-quality NB-EKA Plus II drive and the almost noiseless NB-NanoSLI bearings guarantee operating noise levels which are particularly low over the long term - both equipment features which until now have only been used as part of the costlier Multiframe Reference series.
In addition to the tasteful design in matte black and mirror finish, the BlackSilentPro fans are equipped with an individually extendable cable management system and an NB-Silentframe silicone seal and installation material for vibration-free assembly without tools.
- Noise Level: 9dbA
- RPM: 700rpm
Only £11.99 inc VAT.
ORDER NOW
Noiseblocker Multiframe S-Series M12-S1 Fan - 120mm @ £15.98 inc VAT
The Multiframe S series made by (((Noiseblocker)))®, which is generally recognised as the reference standard, is the first fan with a vibration-free fan frame and incorporates numerous other improvements, so that it is superior to standard fans in almost all aspects.
In conjunction with the unique (((Noiseblocker)))® technology, our almost noise-free NB-NanoSLI® bearing and the NB-EKAPlus II drive, the NB-Multiframe® S series currently represents the best that German engineering expertise has to offer. Quality you can rely on!
- Dimensions: 120x120x25mm
- Noise Level: 8dbA
- RPM: 750rpm
Only £15.98 inc VAT.
ORDER NOW
- RPM: 800rpm
Only £8.99 inc VAT.
ORDER NOW
- Noise Level: 9dbA
- RPM: 700rpm
ORDER NOW
- Noise Level: 8dbA
- RPM: 750rpm
ORDER NOW
