Noisey PSU
1 Nov 2002
Sussex
Chaps,
Running a OCZ 1000W PSU, new unit, but its making what I can only describe as a noise akin to that of a hard drive. Its so loud it can be heard outside the case.
I currently have it with the fan down sucking air through the bottom of the case but am contemplating turning it upside down first before I try and find a differrent solution?
Any one any experience with a similar noise?
Well try it upside down and also see if something is catching the fan inside.
If it continues and nothing is obvious then RMA it.
