I bought a 2060FE from NVidia 2 months ago to the day. It has developed this weird noise on the fan furthest from the back plate. I wasn't sure what was making the noise so I ripped the system apart and just put in the GPU to start with an it was immediately apparent it was at fault for the noise.
The noise is like an annoying whirring noise, not like regular fan spinning noise and not like coil whine (at least from what I can gather). The fans don't go below 32% but if you physically stop the fan the difference is instantaneous and very pronounced. Stop the other fan and there is zero change in the noise being made. Anyone else experienced this, or anything similar?
I used the NVidia online chat support thingy tool and they asked the usual questions, yes I had tried everything under the sun, yes I did think I was going bonkers initially, and yes whilst it's fine when gaming it's irritating as heck when just using windows and I use my PC a LOT (i.e. no life).
They seemed pretty fine to accept the fan might well be faulty, gave them my details and copy of the invoice and a photo of the box/serial number. They said they will get back to me regarding a replacement. All seems a little bit too easy, I'm waiting for the "Er tough luck mate, its just fan noise" email.
I shall update with how it goes but was curious if anyone else has experienced this, or anything similar and if so what was the outcome?
Cheers
Cheers
