Noisy Brakes!
  • Thread starter Thread starter box
  • Start date Start date
box
box
20 Nov 2005
Bristol
I have a 2003 VW Polo. For a while now my brakes have been screeching very badly whenever I use them. Upon visible inspection, the pads have very little wear, although the rear drums are extremely rusty. I have not changed any of the braking system since I bought the car 6 months ago, although the AA engineer who checked the car said the pads were in good condition so I have had no reason to. I am also assuming the relevant warning light would illuminate if the pads are worn?
Either way, they make a horrible noise which I can't seem to avoid. It will only occur when I brake lightly though, and only when the brakes have been warmed up after a bit of use. Any suggestions?
Also, recently I've starting getting a noise I can only describe as a 'yelp' every time I lift my foot off the brake. It is quite loud and very audible from outside the car. It will only occur when I am using the brakes to stop the car though. ie. it won't happen if I just sit at a standstill pressing and releasing the brake. Has anyone come across this?
Many Thanks
noise is caused by vibration so check that everything that needs greasing is greases and check that everything that should be tight is still tight
