- 16 Sep 2009
Hello,
Lately my PC is emitting a lot of noise, usually when playing CS:GO or other games. Spec:
AMD Piledriver FX-8 Eight Core 8320 Black Edition
Gigabyte 990FXA-UD3 AMD 990FX
Corsair Builder Series CX 600w Modular
Samsung Green (MV-3V4G3D/US) 8GB
ATI Radeon 5770 1Gb
1x SSD 3x HDs
Antec 302 Three Hundred Two Ultimate Gaming Case
I believe the sound is coming from the fans although I don't know which ones, it is usually quieter after I turn case fans to Low. I have cleaned the inside of the case, there is no dust under any fan in the system. I can get stupidly loud and physically makes my desk vibrate.
I've run SpeedFan and under load the CPU does not go over 42 but the GPU can go up to 60 degrees.
How can I reduce noise? Would replacing my stock case fans help much? How much would upgrading the graphics card help?
Thanks
ATI Radeon 5770 1Gb
1x SSD 3x HDs
Thanks
