- 3 Jul 2006
- St. Neots
The fan has got real noisy on a friends SG33
Its only running a E2140@stock circa 23c idle
Should I replace it with another 4pin PWM fan?
Or do you think I would do better just getting a new CPU cooler?
Was thinking the AC Freezer 7 Pro if it will fit. Need to check the height out for mounting!
Or the AC Alpine 7 Pro. Anyone any ideas?
Cheers guys
Cheers guys
