Noisy CPU PUMP
14 Apr 2012
High folks I have one of these installed as of yesterday http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-IN
it was fine at first perfectly quiet then all of sudden it started making a grinding kinda sound. Looking around on line people with other types of water cooler have said its air.
Does anyone know a good way to get it to shut up again it's very loud, feels like I'm trying to use a washing machine to access the internet.
hmmmm, as its a closed loop setup, it probably means the pump is busted. Either way, unless it goes away by itself, it's most likely you'll need to send it back for RMA if its still in warranty.
If it had began with the noise first I would suggest letting it settle over a day or two. However, as it is the opposite I would suggest a return.
With closed loop coolers ive heard laying the case on its side so the pump block is horizontal (for a couple of hours) can help any air escape from the pump which causes the noise.
