- 6 Jul 2009
Hi All
I bought some components from overclockers and assembled a PC. One of the components was a Corsair Hydro H50 Liquid CPU cooler. I bought this because I thought it would be a quiet device but sadly I was wrong. I have put up with it for about 3 years now but have now started recording music on my pc which means that on occasions I need to use a microphone in the same room as the pc.
To cut a long story short the fan for the H50 is too loud and I need some alternative.
Can anyone recommend a solution?
It doesn't have to be a water cooling system. Just some way of affordably cooling my I7 quietly.
My system consists of the following :
Corsair Hydro H50-1 High-Performance Liquid CPU Cooler (Socket LGA775/1155/1156/1366/AM2/AM3)
Intel Core i7 950 3.06GHz (Bloomfield) (Socket LGA1366) - Retail
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard
Thanks in Advance
Thanks in Advance
