Nokia 6600 Stopped Vibrating
17 Oct 2002
Ipswich
My 6600 seems to have stopped vibrating :(
It is set to vibrate on incoming calls and texts but doesn't seem to do that, is there any code I can enter to test the vibrating feature? I have fiddled around with the profiles and restarted the phone but it still doesn't want to work.
Any advice?
can't remember a code off the top of my head, but you could open it up an see if there is any dust blocking the connectors of the vibrating unit, that happened to me before on a few phones
Common nokia problem i'd say, all 3 nokia's i've owned have had vibration motor failure. Dusty contacts seems like a plausable explanation.
Oh and dont forget that opening up your phone will almost certainly void the warranty so bear this in mind.
