Nokia E71 - Keypad Suddenly Unresponsive!
25 Jan 2003
Hi
Yesterday I was using my Nokia E71 as usual. Put it on the side, come to use it an hour later, and the keypad wouldn't work. Nothing, nada!
The only button that will work is the off button on top of the phone. Luckily there is no pin code on it! Ive tried starting the phone with no memory card, no sim card etc but still nothing.
However, I can connect the phone to my PC via Nokia PC Suite and still make and receive calls and send and receive texts, so its defiantly the keypad at fault by the sounds of it.
Anyone have any idea if its worth taking it round a few phone shops to see if it can be fixed, or would it cost more to be fixed than the phone is worth? (Assuming its worth around £130ish on the bay!)
If anyone has any other idea's, I'd appreciate it, as i know there is a few E71 owners here!
Cheers
