nokia maps
16 Sep 2005
What used to be a UK
Can you download all of the nokia maps using a pc and simply use them where and when needed without accessing the internet simply as a street map? I don't have internet access on my phone due to the tesco network so if I used the maps I would be quite content to use them for info only. Thanks
Simply yes.
Would help if we knew what phone you had though, does it already have Nokia Maps installed?
N95. It has something called maps in applications but when I try to use them noyhing happens, that is it cannot find or search anything: so I assume the app is there minus the maps lol
