Nokia One Touch Access problems
Man of Honour
17 Oct 2002
Hi guys,
I use my N95 8Gb as a 3G Modem for my laptop. Last week, it suddenly stopped working.
PC Suite works perfectly and syncs with the phone, etc etc. No problems.
One Touch Access now no longer works. It just says connecting and nothing happens. In the settings section, the dropdown box to select a modem is blank. There are no choices to make, I cannot select a modem to use.
The 'Standard Modem over Bluetooth Link' modem driver is correctly installed and appears in both Connections and Device Manager, as it used to when it works.
I have completely uninstalled and reinstalled Nokia N Series PC Suite, including the latest version, on 4 occasions now. It remains broken.
What has gone wrong? :confused:
Thanks
Don't suppose you have another computer you can try it on? That way you can isolate what's causing it.
I had this problem a while back, incidentally (I think) just after I installed the TomTom bluetooth gps hack. I ended up flashing my phone and it resolved the issue.... (I since reinstalled the tomtom hack and it works fine now) :shrug:
