Non-existent USB device installs repeatedly
10 May 2004
Sunny Stafford
All USB devices are currently unplugged (even going back to PS/2 keyboard atm). Despite this, something installs itself, comes up with "USB device not recognized" in a bubble by the clock, disappears, then comes back. Repeat >20 times in the time it took me to write this. You hear the ding-dings as well. I don't think it's a faulty port because I inserted a USB stick which came up fine on all ports. Just using mobo ports for now. Front ports/sound jack connector is currently disconnected. No card reader present. Any ideas before I lose my sanity?!
Have you checked every USB port on your computer that there isn't a rogue spider in there LOLing by shorting the pins?
Does it have onboard Wifi etc? Some manufacturers will use USB versions of these to save money and will wire them up directly to the chipset.
Thanks for the suggestions.
- no WLAN devices present
- turned PC off/on to no avail
- have checked ports, bit of dust but no arachnids as far as I know
Here's something interesting though: the motherboard only has 4 USB ports but in Device Manager, "USB Root Hub" is showing up as having 10 ports.
When I plug a USB stick into ports 1, 2, 3 or 4, the location shows up as Port_#0001.Hub_#0001, Port_#0002.Hub_#0001, Port_#0003.Hub_#0001, Port_#0004.Hub_#0001 respectively. However! The offending non-existent device shows up as Port_#0005.Hub_#0001... USB port 5! Where the hell in my computer is that? Or are 5-10 'logical' location as opposed to physical? If that's the case, how can I disable these ports and thus prevent the message from keep popping?
Could it be an on-board USB header which is shorting ? (you know, that you could connect case or backplate headers to, but haven't ?)
Thanks again guys!
Regarding USB headers, I thought the thing was usually soldered onto the board? 4 ports arranged in a 2x2 block and it looks fairly firmly seated when looking inside the case. The front 2 ports does have a header though and is currently disconnected in process of elimination.
Will have a look at chipset drivers though, last time checked being back in July.
P.S. had Microsoft Security Essentials as realtime scanner since day 1 to rule out virus activity. Windows 7 Home 64-bit.
