Will the non fe 1070s be available to pre order on the 10th as well?
Got a stack of games I'm itching to play that my current 2gb card can't handle
If the 1080 fiasco is anything to go by I think they'll probably be limited.
I'm hoping EVGA learn from the 1080 delays and get 1070s out a bit earlier... Buuut don't hold your breath.
I'd expect the first batch around the 28th, if the 1080 is anything to go by.
What time do new graphic card launches go live on the website?
In the 1080 thread, Ben from EVGA said stocks of 1070 would suffer the same shortages and delays as 1080s. Sounds more like a yield problem.Lets be honest here. The reason you are waiting so long and stock is scarce is because Nvidia wanted to jump the gun on AMD to release the next gen cards. Knowing full well that they had a limited supply of GDDR5X to go with the 1080.However, this shouldn't be a problem with the 1070 as it uses GDDR5 which is in plentyfull supply.
