NONE Background canceling headphones
Permabanned
6 Feb 2010
Barnsley
Looking for some NONE Background canceling headphones.
When i wear my headphones because i cant here my self talking i start to shout lol ;).
but i have to use headphone because i work night and fine myself gaming at 1 and 2am on my days off. what would be an on set to use.
Looking at a max of say £50, not looking for the best in the world just some i can use and not find myself shouting at 2am
I have some ear-force x12's and cut the foam so that worked fine but are not getting a bit old and i dont want to buy new headphones just to cut up
You mean you're looking for a headset? Headphones won't have a mic attachment. If you are looking for a headset that's the best bang for buck under £50 then check out the Superlux HMC 681 EVO and HyperX Clouds (if it's on sale). They're great cans and the large soundstage helps a lot with directional sound. If you don't need the microphone then check out Takstar Hi2050 or the Superlux HD 681 EVO.
